-   -   7.4 carb-swap 502 mag (https://www.offshoreonly.com/forums/general-q/20307-7-4-carb-swap-502-mag.html)
CAP071 03-17-2002 01:04 AM
I own a 1998 checkmate 25'3 convincor with a 7.4 L motor 454carb/300 HP I want to swap it with a 502 mag fuel injection motor complete unit. I know how to read a manual and turn a wrench, aka busted knuckles ha-ha! What does this job take? is it a complete swap , or do I need extra parts? I live in Phila, Pa.area, any really good shops around me or in NJ?
Thanks in advance!:D
puder 03-17-2002 02:23 AM
teh big pain in teh ass on that job is moving the engine. I pulled my engeina few months back and have it out for work. The switch shodul be esy as long as you have teh right tools. IE a lifting gantry or a fork lift or a really big cherry picker style engine hoist
CAP071 03-17-2002 11:24 AM
Do I need a new wiring harness? or anything like that?
fuel pump?
Budman 03-18-2002 03:21 PM
You will probably need to rejet the carb if you are going to use the one that came on the7.4. Otherwise you will probably be too lean. Is it a Carter, Holley or a Q-jet?
KCHOTBOAT 03-18-2002 05:01 PM
going for a carb motor to a fuel injected I know you need to run electric fuel pump. I believe you also need a return line to the gas tank. I don't know if you can add the required wires or need a new harness.
