-   -   setting up valvetrain (https://www.offshoreonly.com/forums/general-q/203478-setting-up-valvetrain.html)
Fixxxer22 02-18-2009 04:38 PM
i have all my parts in. i just installed my heads. i have hydraulic roller lifters, the correct pushrods, and roller rockers. the engine has not been primed and the lifters have not been pumped up. i have conflicting tips from people. one person said i should tighten the rocker arm till 0 lash then crank it one half turn.. then someone else said i have to adjust it warm.
Jeff P31 02-18-2009 05:15 PM
Try reading this good luck.
http://www.cranecams.com/?show=techarticle&id=2
:ernaehrung004:
1BIGJIM 02-18-2009 06:37 PM
Good article, and exactly how I have done it for decades:eek:
I would suggest checking your pushrod length also.
And last degree in the cam, if you haven't.
Good luck with your build.
Fixxxer22 02-18-2009 06:40 PM
:ernaehrung004:
thank you so much that article helped alot. just what i needed. you know when you are assemebling this stuff you can loose sleep if you are not 100% sure of yourself.
