91 and 95 octane
we can get only 91 and 95 octane fuel, nothing less. its the same price! in the future they are planning to sell only the 95 in austria. should i do a timing adjustment to go with 95 or is it fine like it is?
chris 454 mag |
I have a feeling your motor won't know the difference.
Darrell. |
Originally Posted by chris-jack
(Post 2804776)
chris 454 mag A 91 european octane fuel is actually about 98 US octane !!!!! So u be more then fine actually maybe better off. I lived in germany all my life and had race engines that needet 110 octane fuel in the us and in germany i fueled the 95 or 98 shell super and they where fine . Thats how i know because i had done that research in late 90's. :ernaehrung004: |
Originally Posted by daredevil
(Post 2805124)
Chris,,,in europe the fuel octane is mess. diffrent.
First thing is to find out how your octane measurement compares to US octane ratings.
(Post 2805194)
wow, thats intresting. so, would you recommend me to go with 91 or 95. as i mentioned - the same price. i always thought: the more octane, the better, but lower octane also has its advantages. and maybe this summer there will be only 95 available. adjusting the ignition point could be necessary. am i wrong?
But may wanna check with MARCO HANISCH in Mainz Germany . Don't have his # anymore but he knows all that stuff for shure. Thats who told me and it worked. |
ok, that fine, will call him
Hanisch GmbH Reichelsheimer Str. 10 55268 Nieder-Olm hope this is correct |
Do you know what the compression ratio is on your engines? If it is low to medium, use the 91 octane. If you have a 12.5:1 or blowers, use the high octane.
I bet you do not have high compression with a stock 454 mag. 91 octane in the US is plenty for that motor. |
yes, i know that 91 is enough, but i cant get that stuff!!! what happenz when i use 95? i think there is no problem wih it, but maybe i should think about adjusting something to the much higher octane than recommend.
Originally Posted by Griff
(Post 2805405)
Running higher octane than required won't hurt your engine, it just might lose a little power (very little). Higher octane fuel burns a bit slower, and with a low compression engine you might not get a full burn on the power stroke. Advancing the timing can help if you run into that situation, but personally I wouldn't mess with it. |
| All times are GMT -5. The time now is 04:32 PM. |
