here whe go again
for once and for all, can i use valvoline vr-1 5w50 oil in my 600sci?
Thanks Sake |
Kendall 20w-50
Originally Posted by Sake
(Post 2806602)
Thanks Sake |
I'll be using Mobile 1 V-Twin 20/50 in my 557ci
Short answer..... yes.
Ken |
Originally Posted by minxguy
(Post 2808955)
Ken A 5W in a HP offshore engine? Maybe if you live in Alaska. Too much VI's and shear potential for me. Now the VR-1 20W-50 is a different story. The 5W-50 in a Porsche' 911 Turbo for racing all day long. The 5W formula is a European formula for cars. My .02 |
Originally Posted by Kidnova
(Post 2807377)
Originally Posted by Back4More
(Post 2806815)
Kendall 20w-50
Originally Posted by 07DominatorSS
(Post 2807187)
I like using AMSOIL, but simply put, yes you can use that in your engines.
Thanks allot, i wil put that not! in my engine i buy a 20w50 Thanks again
I don't know what Merc recomends but my builder with ProCharged 720 HP 454's says VR1 50 only.
My $.02 |
Originally Posted by Hydrocruiser
(Post 2809424)
http://www.valvolineeurope.com/uploadedFiles/1200.pdf
(Post 2812787)
Its still a 50 weight. Period. People on here are so stuck on whether its a 5w, 10w, 15w or 20w. As long as the protection is still a 50, it will work just fine.
Ken |
what stands for the 5? and i ask here in holland about the 20w50 that is a semi shyntetik oil and the 5w50 a full,
wil the 5w50 be to low when the oil is cold? does the oilpump not suck up the oil? please can anybody explane? thanks
(Post 2812787)
let me ask differend
why is there a full a semy and a non syntethic oil? |
(Post 2812787)
Viscosity enhancers shear and the oil reduces viscosity faster. 20W-50 has much less enhancers and is much preferred for marine engines. |
(Post 2812898)
wil the 5w50 be to low when the oil is cold? does the oilpump not suck up the oil? please can anybody explane? thanks Maybe this little caption will help too..... Viscosity Improvers Mineral oil lubricants become less effective at high temperatures. The drop in viscosity with heat reduces their film-forming ability. Unbelievably, to try and counter this problem, seasonal oil changes used to be the norm for some applications! Fortunately, with the advent of viscosity improvers, this is no longer the case. Viscosity improvers are polymers added to low viscosity oils to improve high temperature lubrication. They effectively thicken the oil as temperature increases. This means that the lubricating effect of mineral oils can be extended across a wider temperature range. A balance between thickening efficiency and shear stability is important when selecting a polymer for use as a viscosity improver. Higher molecular weight polymers make better thickeners but tend to have less resistance to mechanical shear. Lower molecular weight polymers are more shear resistant, but do not improve viscosity as effectively at higher temperatures and therefore have to be used in larger quantities. Polymer additives can also undergo thermal and oxidative degradation, unzipping back to smaller monomers, which reduces their effect. The highest possible degree of thermal and oxidative stability is desirable in addition to the features above. Viscosity improvers are primarily used in multigrade engine oils, gear oils, automatic transmission fluids, power steering fluids, greases, and some hydraulic fluids. Here is one more real good explanation, also not biased...... http://www.oil-shop-uk.co.uk/acatalo...ear-stable.pdf Basically, you get what you pay for |
Ask a Merc certified mechanic about using 5W-50 in say Florida and see what he says...
(Post 2813500)
I believe you will not find many (if any) marine engine builders who will recommend 5w50 oil. I will not risk an expensive engine with something out of the norm.
| All times are GMT -5. The time now is 04:43 AM. |
