New Bell Engineering Regulator
I just purchased the new Bell regulator 2035 for my 502mpi procharged engines. My question is they told me to put a T fitting at the pump and run one line to the fuel rail and run the other line into the regulator. Does this make sense to you guys?
Originally Posted by baja27
(Post 2815491)
The reason why I went this route, is that the procharger regulator is inconsistent. You would need to have an high idle pressure so you would have enough pressure at boost.
(Post 2815558)
Regulator
after looking at the application this is how they boost their pressure. the problem I see is that they want a 100psi fuel pump in front of this regulator for boost supply. This is not a easy task do to fuel flow (ie) 1to 1 boost.
| All times are GMT -5. The time now is 05:16 AM. |
