Oil leaking past intake bolts
2 Attachment(s)
Minimal leak during cruise at 3400 RPM. Very obvious and a nuisance at RPM over 3800 RPM. I've tried Permatex brushalbe "aircraft" sealant and high temp RTV on threads and base of intake bolt heads. The 2 center intake bolts beneath the carb on the starboard side of both motors give me the most grief.
Is my crank-case ventilation not effective enough? Wrong breather system on valve covers? Wrong sealant? Any suggestions are welcomed. The motors are 509"/550hp with 200 trouble free hours. Thank you |
It may be a fuel leak that has been pooling on a hot intake manifold for a while. Eventually, the fuel ends up looking like oil. This had me chasing an oil leak that ended up being fuel laying on the intake manifold.
....just my experience. Good luck. |
It may be a fuel leak that has been pooling on a hot intake manifold for a while. Eventually, the fuel ends up looking like oil. This had me chasing an oil leak that ended up being fuel laying on the intake manifold. ....just my experience. Good luck. |
Is the oil creeping up past the threads of the bolt?
Are you sure it is not coming from the valve cover and winding up on the intake? |
Is the oil creeping up past the threads of the bolt? Are you sure it is not coming from the valve cover and winding up on the intake? |
We had a similar scenario with a 454 in a pickup - pool of oil looked identical to your picture. We re-set the Edelbrock intake and sealed the center bolts - no more oil.
Ironically, it was also an Edlebrock RPM intake.
Have you checked inside the air cleaner to see if it has oil laying in the bottom, I had that problem awhile back and it dripped down the right side. I changed my crank venting and fixed the problem.
Phil |
| All times are GMT -5. The time now is 01:53 AM. |
