electric fuel pump power source
Hello All
I'm installing a electric fuel and reading some posts according to one they said not to use the positive side of the coil for the pump source. Does anyone have this set-up or what is the proper set-up. Thanks |
You might want to use a relay for more amps to the pump and less draw on the ignition.
power wire
Does that mean to use the positive wire from the coil to drive the coil on the relay terminal 85 or 86 and use a seperate power source to drive the pump. Thanks
Originally Posted by alecsammy
(Post 2821337)
(Post 2821337)
Alecsammy, the answer is YES and NO!!
You run the hot off the coil to 86. You run a 10 Gauge wire from a heavy battery source to 30 (such as the starter post that someone else suggested...I prefer directly from the battery post). You run 85 to ground.
You take a 10 guage wire from 87 to the pump. If you have two 87s, then attached a 12 guage to each one, and Y them together into a 10 guage and continue to the pump (or you could run a 10 from each one and Y to a single 10). By using the hot side of the coil, you will not need a separate kill switch for the fuel pump. Your current kill switch will kill the power to the coil, which will kill the "switch" (86) in your relay. If you are racing in sanctioned races, you may have to have a separate kill for the pump. Scott |
Correction/correction/correction
You can do everything in my previous post except DO NOT use 87A.
Just run a 10 gauge off of 87 to the pump. This thing can be wired so many ways to Sunday, half the time you can make up your own way. Scott |
