-   -   Play in bravo steering (https://www.offshoreonly.com/forums/general-q/205007-play-bravo-steering.html)
Sweet Nmocean 03-16-2009 07:43 PM
How much play should I have in the wheel? I have replaced the helm and cable and also I have checked the gimbal ring and bolt they were all fine. I have gone as far as replacing the rack but it is a new style with quick connect fittings and I have been unable to locate fittings/adapters for my old hoses. If there is supposed to be some play then I am going to put the old rack back on.
trawfish 03-17-2009 02:35 PM
If when you say "rack' you are talking about the hydraulic assist or (actuator) then just unscrew the quick connect fitting and your hoses should screw right in. ** Unless you have the saginaw valve, then I don't know if there is a difference.
Sweet Nmocean 03-17-2009 03:11 PM
There is a difference the fittings off of the old rack will not fit I removed the quick disconnects and my hoses would not fit the pressure side was completely different, the return side was the right size but would not screw in far enough I hate to but new hoses
trawfish 03-17-2009 07:22 PM
Bummer... I just replaced mine (same slop issues) with a new take off that had the quick disconnect fittings and once the fitting was removed, it screws right in.
Sorry , I got no other ideas...:(
Im trying to save for dual rams myself, and be done with the whole issue. :D
Sweet Nmocean 03-17-2009 10:19 PM
I found part numbers today for new hoses that will connect to the quick fittings my old rack was a 93 the new one is from a 04. The psi hose is 102.00 and the return is 35.00
ezstriper 03-18-2009 06:44 AM
are you checking with the boat running ? if not there is no pressure to the actuator to preload the ball and stud, I changed mine to the new style and just replaced the hoses, worked fine...Rob
