-   -   Fueltank return line (https://www.offshoreonly.com/forums/general-q/205027-fueltank-return-line.html)
Secretformula 03-17-2009 08:39 AM
What is the easiest way to add two return ports to a glassed in gastank? I understand this is the way to fix a vaporlock problem on the 502 efi engines.
bcfountain 03-17-2009 10:22 AM
location
i think the easest way would be to buy a fitting that cpperformance sells that goes into the rubber hose that is your gas fill.it has a tee fitting and you can return the fuel that way.i have heard sooo many ways to fix the vst injection that i cannot rember them all.i have a 94 fountain w/the same problem,rough idle,vapor locks sometime,etc,etc.let me know if it works,i am about ready to can the injection in favor or a carb.just dont like the consumpton of a carb vers injection.good luck.
Dock Holiday 03-17-2009 11:36 AM
Originally Posted by bcfountain (Post 2823038)
i think the easest way would be to buy a fitting that cpperformance sells that goes into the rubber hose that is your gas fill.it has a tee fitting and you can return the fuel that way..
+1
Call Mike at CP and he will fix you up.
CPPerformance 03-17-2009 12:15 PM
Hey Secretformula, we do offer this fuel return adapter that should make your project just a tad easier. You can click on the picture for more information. Goodluck!
http://i624.photobucket.com/albums/t.../620-76300.jpg
