-   -   Intake Gasket question (https://www.offshoreonly.com/forums/general-q/205191-intake-gasket-question.html)
crapr6 03-19-2009 08:21 PM
I want to swap out my intake on my 330HP 454. The Intake gasket calls for a Fel Pro part number 1210. Its a Composite steel core laminated gasket. Will this be ok to run since the motor is ran in salt water, but is flushed after every use? If not ok what type of intake gasket should I use for the oval port intake. Thanks
Erik
crapr6 03-21-2009 07:42 PM
Anybody? Will a standard intake gasket be ok in salt water use?
thanks
Erik
DareDevil 03-21-2009 07:55 PM
thanks
Erik
Yes,,standart gaskets on intake are ok.
bcfountain 03-21-2009 07:57 PM
gaskets
i have used the same combo on my 330 in salt and brackish water for awhile w/no issuses.i try to flush after use but have to admit i forget to .but still no problems after 4ys.
MER Performance 03-22-2009 09:07 AM
Call Bob @ Performance Gasket Concepts in Germantown, WI. He has graphite intake gaskets and anyother kind you want Paper gaskets wick water, this are stainless steel core.
crapr6 03-22-2009 10:04 AM
Thanks everyone!
Erik
