Temperature / Pressure Senders
1 Attachment(s)
G'day All,
Is there any difference between the automotive and marine temperature (water / oil) and pressure (oil) sender units for electronic analogue gauges? I ask because I have the gauges installed (oil & water temp, Oil pressure) but all the senders left with the old motor (454 mag) and I want to be sure I put the right senders in the new engine. Will the standard automotive style 'universal' senders work or will their sensitivity range be too high? If they won't work, does anyone have the correct type of senders I should be using and can someone tell me where to get them? (Open loop cooling system and Gil oil cooler) Cheers, John |
I just put a pic up, wow your response was quick!!
I think they're FARIA but the boat's down at my workshop so I can't check! They look like Faria in the pic! |
John there Faria.That dash looks familiar.What senders do you have,i can't remember?Any 0-80 PSI oil sender will work from a GM application.Careful with the water because theres 2.The Alarm sender and the one you need.I don't know the range.Search Ebay you're sure to find one.Hows the project?I've finished paint.The whole thing got done.Starting fit out.
Originally Posted by fastlane40
(Post 2825650)
Robs been busy on the video capturing the progress.Works flat out.Good to here its coming along.T'ville race is in July.
| All times are GMT -5. The time now is 01:41 PM. |
