-   -   7.4 mpi heads to 454 330hp heads question? (https://www.offshoreonly.com/forums/general-q/206063-7-4-mpi-heads-454-330hp-heads-question.html)
obsessioncatsass 04-02-2009 03:53 PM
A friend of mine has a 1998 checkmate with the 7.4 mpi motors 310 hp. His heads are junk. I can get some 1993 454 330 hp heads that are pretty much brand new. Will these older heads work on the newer blocks? I didnt know if the rocker arms etc, was the same or different. Any help on this topic would be a great help, Thanks
jeffswav 04-02-2009 09:02 PM
The 1998 heads should be Gen IV large oval L-29 heads with small chambers. These heads are better than the small ovals from the 330. I have heard of boats in the 1993 model year having both Mark IV and Gen V blocks. Gen V & VI heads will interchange. I have Mark IV heads on a Gen V block but I have been told not to put Gen V or VI heads on a Mark IV block. Hope this helps.
Pat McPherson 04-03-2009 09:23 AM
The heads off a 330 will lower the compression from 9:1 to 8:1 so I would not do this.
The power will drop and the MPI's ECU cal will be off...
getrdunn 04-03-2009 09:42 AM
when you mentioned small chambers what size chambers are you talking about. CC's ... as far as I recall all of GM's heads past early 70's have the open chambers all being near 112 - 119 cc's.
119 being most common.
Pat McPherson 04-03-2009 10:58 AM
L-29 heads are 100-105cc.
jeffswav 04-03-2009 02:12 PM
Pat is correct on both comments. Look on mortec.com and look at the specs. You need to have the casting numbers.
getrdunn 04-03-2009 04:47 PM
I appoligize for my comment. I've been out of the scene for a while and it's amazing how many things you forget. My bad...
