konrad/trs
i have been told that konrads will bolt up to a trs gimble, does anybody know for sure?:ernaehrung004:
you can find all info on there website ,oir call them
http://www.konradmarine.com/index.cfm?optionid=8139 |
Yes, Konrad Conversion come with a different Helmet becasue of the oiling system. So all you have to do is remove the Hinge Pins, replace the helmet. Attatch the drive. You also need to add a new resivoir that is larger capacity then the Trs. Its simple, can be done in a couple of hours or less with a few tools.
If you have any further questions PM Biggus, he is the Rep. The Konrads come with a bunch of manuals and installation manuals. Its very easy |
Here's the manual for the 1/2 conversion.
http://shared.buildmeaportal.com/web...ID9650DOC1.pdf And the full conversion (including gimbal assembly) http://shared.buildmeaportal.com/web...ID9650DOC2.pdf Feel free to call me direct for more info. Kurt 715-410-0735 [email protected] |
& i think biggus has a refirb pair for sale that is very reasonable.
And I have the Ace for sale, which I could break up with the gimble, drive and trans!!
Originally Posted by Elite Marine
(Post 2837467)
The Konrad 540 PRS (TRS replacement) is fitted with an input shaft 3" longer than the ACE unit as the TRS transmissions have a tailstock 3" longer than the ACE trans. Feel free to call for more info. Kurt 715-410-0735 [email protected] |
| All times are GMT -5. The time now is 03:13 AM. |
