-   -   Quadrajet Questions (https://www.offshoreonly.com/forums/general-q/20639-quadrajet-questions.html)
BAD-HABIT 03-21-2002 05:22 PM
Quadrajet Questions
I have a 86 Quadrajet off of my 86 5.7l. I have upgraded to a 1989 roller block with roller cam and L31 Vortec heads. My Quadrajet does not have an electric choke and I will need one since the L31 heads do not have a provision for a heat activated one. Does anyone make a conversion for this? I have been told no. My mechanic says he has some quads with electric chokes that we can swing a deal on...What's the difference between the quads for the small blocks and the bigblocks? Do they have different CFM ratings? Also any suggestions on what jets to use or rods? Where can I get sets? I was figuring on using the 350 mags sizes as a base-line to start. HP should be about 360. Max RPM's will be around 52-5500. Cams rpm range is 13-5200. I am running a performer manifold with the vortec heads. Stainless marine thru-transom 4" exhaust. Compression ratio is 9:3-1. Cam has a duration of 218 and 224 and lift of 503 and 510. All on a 112 centerline. I am using a Alpha one with 1:32 gears and a Mirage 3 blade. Boat weighs 4000lbs loaded.
ANY Tips or info on Quadrajets will be helpfull Sorry about the long post......
"Bad-Habit"
86 F3LS
Blueman 03-21-2002 05:45 PM
They do make different sizes. Try one for older BB I think you can get about 750 cfm. Hope this helps :)
Mbam 03-21-2002 05:57 PM
Unless you do a lot of snow boating (you know, when it is so cold everyone thinks you'r nuts) the chokes should not be an issue. You gain a few CFM if you pull the shaft and butterfly.
Cord 03-21-2002 06:02 PM
The secondary air door is based off vacuum. Many people have run into a tuning nightmare by putting a quad that is setup for a big block onto a small block. I'm not saying that the carb can't be tuned, but you'll have some work to do.
Try contacting Jones Carburation or the Carb Shop. Both of these guys specialize in quadrajets.
jafo 03-21-2002 06:03 PM
Get Dennis Moores's book `Small Block Chevy Marine Performance'
HP Books 2000 (Amazon.com) if you don't already have a copy.
Dennis likes the Q-Jet for SBC's, and will give you all the tricks to set one up, the jet and rod numbers, etc.
350 Mag is a good place to start-I have similar engines in the Formula and had to more aggressive with the secondaries. Jets and rods are available from Edelbrock. Lots of performance gains here! Get plenty of sizes and experiment!
Your Performer should have provisions for a divorced choke- I'm using Performer RPM Q-Jets and have a divorced choke set-ups just like stock, except I had to get a different rods (Edelbrock again) because of the high-rise profiles. I think electric can be had from GM, but the divorced seems to work fine, other than a little longer warm-up time with aluminum manifold vs. cast -iron.
A standard marine Q-Jet for SBC is more than adequate for a 350-355. Strokers may require a little more CFM, but it is rare a SBC needs more than 750.
Jim
BAD-HABIT 03-21-2002 06:43 PM
Jim
What do you mean divorced choke set up? I have the Vortec heads and performer intake. The heads don't have any provison for a standard choke.....
excaleagle42 03-21-2002 07:49 PM
i had quadrajets on my engines. can't say i'm a big fan though. i liked holleys and edelbrock better. although, i would suggest a new edelbrock 650 or 750 marine carb from summit racing for $261. they already have an electric choke. you just hook up a hot wire to it and a ground to the manifold. i would say the 750cfm because of the mods. to your engine and the stock carb would be close. the 650 would work too but you may need it a little fatter. you will need an adapter plate too around $20. a new holley is twice as expensive.
i'm sure people are reading this and are going to spew the minimum carb sizing formula and say 750 is too much but if you ever need more air because or the mods you may make in the future, you won't have to buy another carb.
Vinny P 03-21-2002 09:18 PM
On my last boat, I ran into the same problem as you with the choke. My solution was to wire tie it open. It worked fine that way. As far as jetting goes, as other posts have mentioned, Edelbrock makes several different size metering rods for that carb. I got mine from Summit. Do yourself a favor, just order all the sizes they have for the secondary rods, they are cheap enough. You will need them to play with to get the motor to run right. I was able to get away with leaving the primary side stock, saves fuel that way. REMEMBER, when jetting quadrajets, the smaller the diameter of the metering rods, the more fuel it will deliver.
enticer 03-21-2002 09:24 PM
F3LS.......
I have a new Quad in the box..this is a copy of the ad I have on another site.
Mercury Quick Silver PT# 1347-9863A-3 Quadrajet Carburetor Assembly "Marine Use Only" was purchased to replace a carb on a 454 Mag engine..the boat was sold and we still have the carb in the box.
jafo 03-21-2002 09:59 PM
A lot of it comes down to what RPM you spend the bulk of your time at while boating- the Q-Jet is more fuel efficient if you tend to cruise. I have seen guys with built SBC's get zero benefit from going up in CFM size to 750 unless they have stroker SBC. There are enough choices availablein jets and metering rods to get it right with the stock carb, which will flow more than enough air- you just need to get the fuel metering right.
I have modified/ported Sportsman II heads and EFI Thunder exhaust, and have the Q-Jets working just fine (after some patience with a bunch of different rods). If you choose to go with a choke, the divorce set-up as supplied by Merc has nothing to do with head design or model- it mounts to a pad on the intake. The Edelbrock carb is a good design as well- very similar and actually improved in some areas over the original Q-jet, as well as the simplicity of the electric choke. Just have to cough up the cash for it.
TomZ 03-22-2002 12:15 AM
Jafo,
The problem is that there is no heated air going through the Vortec manifold and head (the port in the head for the exhaust crossover is cast shut). The manifold never reaches a high enough temperature to cause the choke to open and there is no pad or well to attach the stove.
With mine I removed all of the pieces that were part of the choke assembly. There is no shaft or butterfly assembly. I worked with the jetting, metering rods, and power valve spring to get the carb spot-on. With precise tuning you can get the engine to run without the choke... mine did. To warm it up I kick the idle up just a bit while loading her up. By the time everyone is on the boat and gear/food and drinks are stowed she's ready to go. She'll take off dead cold as well but I usually let her warm up before leaving the dock. The point is that you can tune the Q-Jet to work very well. It shouldn't be too hard to dial in. Just pick up all the jets and metering rods that you can afford (they are cheap).
Tom
jafo 03-22-2002 12:25 AM
TomZ- Thanks for the clarification. I wasn't aware of that with the Vortec set-up.
Whiteknuckle 03-22-2002 07:41 AM
jafo and TomZ gave some good information. Do pick up Dennis Moores book. The full Q-jet tuning kit from Edelbrock can be purchased for about $100.00 give or take. It is much more expensive to buy individual rod sets from a GM dealer.
You will also find that the choke will not be much of an issue. Try operating the boat without the choke before you invest in anything else. Most likely with some warm up time it will be fine.
I think the Q-Jet is a good choice for moderate HP engines. Low speed operation is great, fuel consumption at cruise is good and top end power is good. You will not have to change the primary side of the carb much if at all. There is a guy in my area that only works on Q-Jets. His company is Q-jet Specialists. If you want any info on him e-mail me.
Good Luck.
