-   -   Hydraulic Steering - do you keep the tiller arm? (https://www.offshoreonly.com/forums/general-q/206774-hydraulic-steering-do-you-keep-tiller-arm.html)
Ghostrider 04-12-2009 06:39 PM
1 Attachment(s)
G'day all,
Just looking at the transom assembly while I've got the motor out. When you've got full hydraulic steering (IMCO), is there a need for the tiller arm from the old set up? Can I remove it or more importantly should I?
(Mind the wiring etc in the pic, I've cleaned it up a lot since then!)
Westcoast 04-12-2009 06:43 PM
If its in the way just cut it off. That is how fountain rigs there boats.
Sledge Hammer 04-13-2009 09:38 PM
I just left mine.
Thunderstruck 04-14-2009 06:58 AM
The arm also functions as a spacer on the upper swivel pin for the gimbal ring. You can cut it off but you need to keep the spacer function intact.
Ghostrider 04-14-2009 05:03 PM
Excellent thanks!
That's all I needed to know.
I think I'll leave well enough alone, especially now I know it's a spacer etc.
Cheers! :drink:
articfriends 04-15-2009 12:49 AM
2 Attachment(s)
I trimmed mine off a few years ago then sanded the edges/re-painted it before re-installing it. Not on is it a spacer but it clamps on the swivel pin,Smitty
articfriends 04-15-2009 12:52 AM
I also cut the ears off then trimmed the inner transom plate where the cable attached (in your pic the drive lube bottle is next to them) to un-clutter the engine compartment,Smitty
Ghostrider 04-15-2009 03:52 AM
Oh yeh! I hadn't thought of that, Good Idea!
I may just do that now, thanks!! :drink:
MadMat 04-15-2009 03:55 AM
That sounds interesting! Do you have a pic of the earless transom plate?
