-   -   Sea Pump priming???? (https://www.offshoreonly.com/forums/general-q/206816-sea-pump-priming.html)
GSELITE2000 04-13-2009 11:40 AM
I ran my boat Saturday for the first time. No tempature reading on the gauge. Had plenty of water from the sea pump, and aways has when running in a trough at home (I do not use water muffs).
On Sunday I worked on various things like the timing and ran the boat with good water flow.
THEN, I replaced the water tempature sender in the thermostat housing. Cranked the engine, no water flow from the Sea Pump.
Is it possible that an air lock was created? What do I do with this situation?
Just seems too odd to just quit like that.
Scott
Jeff P31 04-13-2009 04:46 PM
After sitting all winter my guess is the blades on the pump dryed out and broke off while you were running it. I would start by checking the pump. Just my .02 Jeff :drink:
jeffswav 04-13-2009 05:26 PM
If your pump is working correctly any air will be forced out. I would do like p31 said and check your impeller. How many hours do you have on the impeller? Has it ever been ran dry?
MER Performance 04-13-2009 07:52 PM
I agree with the last two guys, sat all winter and ran the boat and the impeller failed. thats why they should be replaced once a year, made sure you remove all rubber after the pump and account for all the blades, back flush the system.
