-   -   Broken Intake Valve (https://www.offshoreonly.com/forums/general-q/206846-broken-intake-valve.html)
tjsmk8 04-13-2009 08:00 PM
Broken Intake Valve
Anybody ever seen anything like this?
http://img245.imageshack.us/img245/184/dscn1621.jpg
http://img245.imageshack.us/img245/1794/dscn1619j.jpg
MER Performance 04-13-2009 08:12 PM
Are those areas burned?
MER Performance 04-13-2009 08:13 PM
Remove the valve and look at the seat.
tjsmk8 04-13-2009 08:23 PM
It looks like little pieces were breaking off, not burning. I'll be tearing the heads down later this week and updating with seat pics if I find anything.
MER Performance 04-13-2009 08:34 PM
Try to see who makes that valve, I have seen pitting on valves from water on mostly the stem side, thats really strange! Looks like the valve rotates to one spot then begins to remove material, I take it the engine would back-fire through the intake.
tjsmk8 04-14-2009 05:02 AM
As far as I know, the valves are factory but I'll check today. The engine actually ran fine with no backfire. I'm tearing it down due to a bit of oil consumption and found this by surprise.
jeff1000man 04-14-2009 05:13 AM
Are you the original owner of the boat?
Are all the valves this way, or just a few?
There is a lot on info out there that would help, like what kind of engine is this? How, old, how many hours, salt/fresh water?
jeff1000man 04-14-2009 05:14 AM
It might be just me also, but it looks a little lean hot in that chamber also. Are these factory engines?
Vinny P 04-14-2009 03:20 PM
What I find unusual with this, is that the intake valve appears to have gotten hot, not the exhaust??? Weird.
tjsmk8 04-14-2009 03:36 PM
It is only one valve that has done this. The engine is a 9.0:1 454 with fact rectangles (088's). The valve are original from merc and have approx 100 hours on a valve job. I don't know the total number of hours. The cam is stock with 1.8 rockers and the exhaust is stock as well. It is used in fresh water only. The engine was tuned with a LM-1 and ran approx 12.5:1 at wot.
