-   -   LED Lighting problems (https://www.offshoreonly.com/forums/general-q/207071-led-lighting-problems.html)
bert4332 04-16-2009 09:11 PM
I purchased two led replacement bulbs, 19 L.E.D. S25 LED Light, from http://www.ledlight.com/s25-19-led-light.aspx
I pulled my single bayonet incandescent bulb from my cabin and replaced it with the led, same single bayonet, turned on the switch and nothing. Put back in the incandescent and it comes on no problem. I believed these were basically plug in play, am I missing a converting issue?
thanx
redbud35 04-16-2009 09:16 PM
There is a polarity with LED's. Could that be your problem?
bert4332 04-16-2009 09:59 PM
I flipped them, swapped them, tried multiple bulbs, tried everything.
Audiofn 04-16-2009 10:22 PM
Do you have a dimmer in line? Led's work in a very small voltage range. As has been mentioned they are diods so you have to get them in the correct way. Have you tried to just put power to the LED's out of the boat? Like from a battery?
bert4332 04-16-2009 10:27 PM
No dimmer, just a straight switch, I have 4 total bulbs, 2 per pack, I doubt all 4 are bad, but I will try the battery test just to satisfy my curiosity.
Anarchy Powerboats 04-17-2009 02:31 AM
what is the link to the product you purchased?
bobbowobbo 04-17-2009 06:10 AM
thanx
swap the wires going to the light socket and try it again:ernaehrung004:
bert4332 04-17-2009 08:16 AM
Anarchy Powerboats 04-17-2009 01:01 PM
without seeing it I would have to say it is a base incompatibility issue. Have you seen the new light go on at all? You cant test for continuity with led's unfortunately so you need to hold bare wire to it to test.
Audiofn 04-18-2009 07:06 AM
They do make continutity testers for LED's most good mulit meters will do it. It is polarity sensitive. If no multi meter go with the poor boys aproach and just touch the contacts with power. If it lights then your base is not working as Metal Bros. pointed out.
Jon
bert4332 04-19-2009 11:04 PM
Well took apart the light assembly for the festoon led, it was a polarity issue. But back to the bayonet, I couldn't get it to work, what's strange is the connectors line up exactly like the old bulb. So I need to take apart the lamp assembly and see if I can get another socket that will work with the led, I'll try to swap the wires, but since I was putting in the buld both ways it should be the same thing.
thanx for all the help
