-   -   Way OT, But need help with my Banshee (https://www.offshoreonly.com/forums/general-q/20714-way-ot-but-need-help-my-banshee.html)
HiPerf2000 03-22-2002 03:00 PM
There are alot of great motor techs on this board, and i was hoping to find someone who is experienced in Two stroke carburation. I've been to ATV boards, but the replies are slow there compared to our board.
I've got a 2000 Banshee that i just rebuilt the top end (stock bore). Had it out and ran good. I decided to put FMF Knarly pipes on it, and jetted the carbs (stock 26mm Mikuni) to FMF's recommendations - 260m and 30p. I put it all back together and now is backfiring/poping when trying to bring up the Rpms. Once past this range the motor runs great. So i would think i am lean on the pilot circuit (i open the choke half way and i can throttle up much better). The only other mods are a boost bottle and K&N filter. I am using the stock airbox with the snorkle removed.
Someone told me i may have the slides in backwards. When i reassembled the carb(s) the slide had a grove that had to mate with a locater (set screw) comming in through the bore of the carb. So they can only go in one way right?? And yes i have the little hose that connects both carbs connected.
Anyone have any ideas?? i don't think i should have to go above 30 in the pilot...I've talked to other people who never changed thier pilot when installing pipes (left it at stock 25). I may pull the carbs off and clean them again...maybe i got dirt in the pilots???
I want to go riding this weekend :(
mxz800 03-22-2002 04:15 PM
when i built my quadracer years ago i would make a run down the road at say 1/8 throttle kill the motor check the plug. i would do this with 1/8 1/4 1/2 3/4 full i would compare all my readings and go from there. have you adjusted air idle screw? you may need to move the clip on the needle a little. first you need to determine if rich or lean condition. keep us posted
HiPerf2000 03-22-2002 04:24 PM
I've turned both the air mix screws out two more full turns (now at 4 turns total).....still running like chit. It has to be a lean condition if it stops backfiring/poping when i close the choke half way...You would think anyway???
CheckmateF1 03-22-2002 04:46 PM
Hi-Perf, Did FMF say anything about lowering the needle clip position? That's 1st thing I would do. Start with one position lower. See how it runs.
Air mixture screws need to go in to richen the mix don't they? i.e. run the screw in to lessen incoming air.
Eric
HiPerf2000 03-22-2002 04:53 PM
FMF gave these jet sizes based upon the needle being in the stock position. Is the needle easy to move -- just taking off a clip and moving the needle down a notch?? Wouldn't a downward needle movement reduce fuel flow??
CheckmateF1 03-22-2002 04:56 PM
Move the "clip" down to "raise" the needle. It's pretty easy. Pull the slide out and the needle will come out thru the top of the slide. Move the clip and reinstall.
Eric(former TRX250R guru)
hp500efi 03-22-2002 05:55 PM
Checkmate is right on.
Lower the "C" clip on the needle and that will raise the needle thus allowing more fuel into the carb at idle and 1/8-1/4 throttle. Try lowering the clip ONE notch and test. If a little better but still not right, lower clip ONE more position and give her hell. Make sure you check each carb on your ride so that each carb is the same. It is real easy to count the notches wrong on one carb and mis-position the other carb.
Pulling off the "C" clip is also a trick. What I do is take the needle with the clip attached and place it on a hard work surface. Position the needle down on the table with the "open part" of the "C" touching the table. Gently push down on the needle so that the needle pops out of the clip. If you try and pull the clip off the needle, guaranteed that it will go flying across the room not to be found. I also attach a needlenose pliers to the clip as I am pushing down on the needle just in case the bugger decides to go flying.
Good luck.
89 TRX250R man ;)
NASTY HABIT 03-22-2002 06:49 PM
Make sure you didn't crack an intake boot..
HiPerf2000 03-22-2002 07:18 PM
i am going out now to try to move the needles up (clip down)...i'll update you guys with my progress.
NASTY HABIT...the intake boots are rubber, but i'll spray them while running to see if i can find a leak.
thanks guys....any other ideas while i try this??
NASTY HABIT 03-22-2002 07:37 PM
That'll work.... 2000 they shouldn't be cracked but never know... if you try everything and are still having problems.. you may want to consider hitting the water instead...... or get a Honda kidding...i miss my 250R shoulda never sold it
Bruce 03-23-2002 12:03 AM
The pilot typically controls the idle circuit and just off idle. If the engine doesn't respond to the neddle changes, check your ignition timing again. The info provided about the needle is correct and should help your transistion, if it doesn't verify your timing.
Geo 100 03-23-2002 03:54 AM
I had to read your post twice but FMF told you to change pilot to 30, then I would do that first with needle centered, and then adjuct clip position. Pilot is amount of fuel and needle taper dictates how much and how quick. DON'T RUN LEAN Properly jetted midrange builds alot of tork. Good luck
CheckmateF1 03-23-2002 10:09 AM
So what's up Hi-Perf? Did that help?
Eric
HiPerf2000 03-23-2002 10:45 PM
Raising the Needles WORKED!!! It still backfired slightly until i fine tuned the fuel/air mix....Then it ran much better!! FMF also said to run without the airbox lid snorkel...so instead of the 1-1/2 inch round opening for the airflow, you have an oval 4 x 1 inch opening that flows much more air. This kept me a bit lean...so i ended up (don't laugh) duck taping half of the airflow opening to make it 2 x 1 inch. This cut off some airflow and richened me up! I know it's probably not right, but it's running great, so i'm leaving the duck tape...i may just get a black marker and color the tape to make it match the airbox :D :p
Thanks for all your help
Sydwayz 03-24-2002 01:10 AM
Thay make black duct tape.
NASTY HABIT 03-24-2002 07:17 AM
can you just drill some holes in the lid..... glad you got it worked out.. those problems can be a real b$%@&...... have been tinkering on a turbo bike that is running rich for the last few weeks.. i think it's time to yank that s&s off of it and get a mikuni
