Direction of 496 Impeller? HELP!!!!
1 Attachment(s)
I have an 2002 496 (not HO). Impleller is so blown out, I can't see which direction for the new one. I have two hoses on mine, a smaller one on top, and a bigger one on bottom. I am thinking the water intake is the one on top?
Does anyone have any ideas? Boat is 2002 Sunsation Aggresser. Thanks! |
make sure and clean out all of the pieces in the cooler. Put enough grease or vasoline on it and it doesn't matter which direction it is going, It will change itself.
Counter clockwise looking from the rear if I remember correctly. It will straighten itself, but it is hard on the vanes.
Originally Posted by speedreeder
(Post 2847193)
Definately going to use vasoline, pick up some tomorrow. |
Thanks for the help guys!
Tom |
Here's a quick drawing of how the impellor vanes look in relation to the housing. hope it helps.
The inlet is the smaller hose. |
Use liquid dishwashing soap for lubrication. It will disolve in the water and not risk clogging anything when you fire it up.
Originally Posted by raeburn
(Post 2847271)
Originally Posted by 4mulafastech
(Post 2847302)
Thanks! |
Originally Posted by Scarab22-1998
(Post 2847244)
Well that is kind-of what I was thinking, but tomorrow I am going to trace the hoses and verify the water intake line, I also going to just 'tap' the starter to see which way the pulleys are turning... trying to put the whole picture together.
(Post 2847313)
Wow! This is great! Thx! Really appreciate the help!
(Post 2847317)
Yes, I actually bought 'Dawn' dish washing liquid today, but then someone else mentioned vasoline. Seems like vasoline, used sparingly would provide longer lubrication, but I agree that it wouldn't wash out like dish soap. I'm going to fire up the motor right after I'm done, so probably no risk of the soap drying up.
Thanks! Ken |
I bought the water pump rebuild kit from the R&R guys. Too many grooves in the cup and backing plate. Seems they have a pretty good solution.
http://www.randrproducts.net/product...waterpump.html |
| All times are GMT -5. The time now is 05:36 AM. |
