torque specs
where can I find or who knows the torque for alum. heads with arp bolts, and the torque on the alum. intake manifold.
Thanks Larry |
Larry,
With ARP's fasteners you really have to use the torque that they specify, along with the proper sealer or lubricant depending on whether your block has blind head bolt holes or if they go through to water. If you dont have the instruction sheet that came with the bolts, then wait till Monday and call ARP. Bill Koustenis Advanced Automotive Machine Waldorf Md |
Intake 40 on steel with stainless bolt pulled out on me:eek:
I'm back to 35,with ARP stainless 12pt wilth arp sealer I would think the alum prob be the same ,same clamping force on the gasket?Usually they want ya at 80% of yield strength stock bolts My Chevrolet service manual states 80 ft. lbs. for iron heads and 65 ft. lbs. short bolts / 75 ft. lbs. long bolts for aluminum heads |
Thanks for the info: I will call ARP on Monday
Larry |
| All times are GMT -5. The time now is 12:48 PM. |
