-   -   Shifter hard to move..Bravo 1 (https://www.offshoreonly.com/forums/general-q/207448-shifter-hard-move-bravo-1-a.html)
jwurl 04-22-2009 07:20 PM
Before I buy a new cable, i thought i would ask this question first. My shifter is pretty hard to move. It takes a decent amount of effort to get it to shift in and out of gear. Is there anything i can grease or lube to get this to move easier before I buy a new shift cable??? I just installed a new Livorsi shifter assy and the throttle moves like butter... My drive is a Bravo one.. Thanks, Jeff Wurl
Jeff P31 04-22-2009 08:28 PM
I would undo the shift cable at the engine and try moving the shifter first before changing any cables. That will at least tell you which end to start looking at . If it did not shift hard before I would be looking at the new shifter first . just a thought, Jeff :drink:
Mr Gadgets 04-22-2009 08:33 PM
Jeff, pull the drive off and try moving the shifter.. still like butter, then drain the oil down and pull the back cap.. there is a detent ball and spring there.. Make sure it is intack and well greased.. Other wise.. it may be the cable..
Hope this helps.
Dick
Brad Zastrow 04-22-2009 10:32 PM
Most of the time it is a cable. They are cheap but pain the in rear to replace.
800XCR 04-23-2009 07:38 AM
Are you trying to shift it without the engine running?
jwurl 04-23-2009 07:23 PM
I am shifting it with the engine running. I will unhook the cable this weekend and see how easy it moves. Thanks, Jeff
Sick Stinger 04-23-2009 08:42 PM
Lower shift cable from mount point on engine to drive im doing my 2 this wekend aboit 150 for complete kit
-Mike
Sweet Nmocean 04-24-2009 08:30 AM
What about the little ball and spring on the back side of the drive cover? Mine was stiff and the ball and spring needed greased up.
MnFastBoat 04-26-2009 04:22 PM
Hope this helps.
Dick
Funny how we have come across this one before ;)
I concure here, take the back cover off, will loose some gear lube :(
need a 12point socket for the bolts, I think it was a 3/8 i had and was able to use :( yea I know it should be metric.
but was able to soak the detent and lube it back up to all is well.
Part was less then $30 however it was a 7-10 day lead time :(
Take the cable off the engine mount, but then it could be your connection with the new shifter.
Sweet Nmocean 04-26-2009 09:00 PM
I found the ball and socket on mine bound up over the winter repaired it and greased it etc. I thought I found the problem, I even replaced the cable to the drive, it seemed stiff when I removed it. It works fine with the drive disconnected put the drive on it is stiff as it was before. I didn't change the cable from the shifter back to the motor
