-   -   blower surge (https://www.offshoreonly.com/forums/general-q/207625-blower-surge.html)
johnnyboatman 04-26-2009 08:34 AM
blower surge
they are 871s w 1050 dominators is there anyway to adjust the carbs to get the roll out of the idle, kinda hard on the drive if i miss the low side of the idle.
eichhoma 04-26-2009 09:31 AM
Some of it can be adjusted out, but that is typical of blower motors. On mine, it took some tuning to find that happy spot were the roll is no more than 500 rpm, and we tested shifting into gear at the top of the high side so it catches when it is at the low end of the roll. You can find the happy medium where it isnt idling too high and doesnt die at the low end of the roll when you shift in gear. Its really hard to get it all out.
getrdunn 04-26-2009 11:54 AM
idle
I agree.
John
blue thunder 04-26-2009 04:32 PM
The best way to get it right is to tune the 1050 idle with an a/f meter. Adjust the idle mix screws for 14-14.5 a/f at idle. Then don't let it idle too low or surge will start. Set the low side to 800 -1000 rpm.
jdnca1 04-26-2009 07:27 PM
Easiest way to do it is to fatten up the idle circuits. If that doesn't work then you can get into the air bleeds. :drink: Mine only surge about 200rpm with some pretty nasty solid rollers.
ezstriper 04-26-2009 08:00 PM
also lock the dist advance, and set at 26 deg, that will help clean the idle up as well..Rob
