-   -   sea water pump hoses (https://www.offshoreonly.com/forums/general-q/207637-sea-water-pump-hoses.html)
johnnyboatman 04-26-2009 04:16 PM
which hose goes on top,the suction or discharge
johnnyboatman 04-27-2009 09:50 PM
t.t.t help
DareDevil 04-27-2009 10:06 PM
Should say on the back of the pump ,,but i believe its the discharge !!
Usually they are side by side and not top and bottom.
U can loosen the bracket and turn it ?! So really no telling !!:eek:
plumb crazy 04-27-2009 10:07 PM
Your sea pump can be tured both ways . Look on the back it should be marked.
Boat Tech 04-27-2009 10:34 PM
What engine and year do you have?
jdub 04-28-2009 06:00 AM
suction on top
Thunderstruck 04-28-2009 07:04 AM
If you have the one piece plastic housing from Merc the suction goes on top for a normal rotation motor.
GSELITE2000 04-28-2009 07:25 AM
On the one piece, they are marked on the back LH and RH.
For LH rotation, the suction hose goes on the one marked LH, and vice versa for RH rotation.
Scott
blue thunder 04-28-2009 11:26 AM
Look at the arrows on the pump. They are self explanitory. BTW my output is on the top with mine and the arrows indicate LH rotation. The pump turns CW looking at it from the front.
johnnyboatman 04-29-2009 10:53 AM
Yes I Learned The Hard Way Burned Both In A Hurry
