-   -   Hull number locations (https://www.offshoreonly.com/forums/general-q/207657-hull-number-locations.html)
jaxx 30 04-26-2009 08:55 PM
I'm looking into a early to mid 80's scarab 38. The owner says the hull numbers could not be located on the rear of the boat. Would there be any other locations for the #'s other than the rear?
mike38scarab 04-26-2009 09:10 PM
On our old 1984 38' Scarab the HIN was on the outside transom below the swim deck. I can't remember exactly when HIN's were required. If you can't find it there I would suspect that it was filled in prior to a paint job, or it may be a stolen boat.
Either way, caveat emtor.
Good luck.
DareDevil 04-26-2009 09:18 PM
They should be on the starboard side about 1 foot from the transom under the rubrail !!!!
They did that because of safety !!!
And i am not kidding u !!!!!!!!!!!!!!:party-smiley-004:
jaxx 30 04-26-2009 11:49 PM
I was pretty sure there was a secondary HIN #. I'll check when I see the boat. Thank you.
tms1155 04-27-2009 10:22 AM
Good luck.
HINS were required from 1973 and up.
