Innovate LM1 or LM2
Looking at Innovate LM1 and LM2. What i have is a single 502 MPI Which one it the pest for me?.
I got a good LM1 off of e-bay for $100. I put 4 bungs and plugs in my pipes (twins). I just moved the O2 sensor to each pipe to read each bank. Once your dialed in you shouldn't have to be messing around anymore.
I bought a new LM2 last yr off jegs. The firmware was out of date when I recieved it so I had to figure out how to get that update 1st. After that, the a/f part worked fine but I was never able to get the rpm to work. I've done everything suggested on thier help site, still no good. The reason I got the LM2 was I wanted the data logging capability. Without rpm there is not data logging so I would have been better off with the LM1.
Originally Posted by blue thunder
(Post 2854368)
(Post 2854368)
It's been since last summer since I tried to get the rpm to work so I don't remember the specifics just now. I do know I did everything they said including wiring in a variable resistor which did not work. I used to go on the forum but after a while the help diminished and there were still problems. I may give it another go this summer but in hindsight, the a/f reading is what I was after and the LM1 does that.
(Post 2854637)
Originally Posted by Rage
(Post 2855414)
I had a problem with the LM1 (plus the seperate RPM converter required to read/log rpm) after a period of time/use. I called their tech support and after trying what I was told that confirmed the unit was not working I received a RM number, returned unit to Innovate and they sent me a working unit no charge. No problem since. My unit plugs into the tachometer feed wire from the ECU for the rpm signal. They were very helpful but you need to call.
I might add that I feel very confident in the a/f readings which is most important when picking a meter. I would buy innovate again simply because of this, the data logging is secondary. |
(Post 2855513)
Good suggestion, I may due that depending on how well my new engines cooperate this season. Thanks.
(Post 2856108)
I think it was Ford Muscle Car Magazine that did a test of the various A/F meters. Some were really inaccurate that cost as much or more than the LM-1. The LM-1 accuracy was amoung the best regardless of price. They stand behind their product with tech support and service. A no brainer.
| All times are GMT -5. The time now is 10:36 AM. |
