-   -   EMI Thunder SS Riser Dimensions (https://www.offshoreonly.com/forums/general-q/207807-emi-thunder-ss-riser-dimensions.html)
Ghostrider 04-28-2009 05:14 PM
3 Attachment(s)
G'day All,
Does anyone run the EMI Thunder SS Risers (the long tube low rise ones)?
The reason I ask is because my Risers didn't fit under the hatch so I've had to buy the EMI Cast elbow risers but I would like to know if the SS low rise ones will fit instead. (preferably before I buy them)
Is the bottom of the riser exit in line with the inlet flange base or lower?
What is the total height from base of inlet flange to top of riser?
The pics are:
Green = the ones I just bought for an immediate solution.
Polished = the ones I hope will fit if I buy them later.
Motor = my current predicament
Cheers, :ernaehrung004:
John
DiamondPerformance 04-28-2009 06:01 PM
The black riser look like 3" Taller Risers.
Rockfish71 04-28-2009 09:23 PM
Originally Posted by Ghostrider (Post 2854630)
G'day All,
The pics are:
John
The black riser on the engine pic is not a eddie marine it is a stock 496 riser that is really taller the the low riser from eddie marine what is your email and I will send you pics with a tape measurement I think they are no higher they the green one you have I have both risers from eddie marine long and short
Ghostrider 04-29-2009 12:27 AM
Thanks Rock.
The black risers are the 496 ones (I know now!) which I bought a while back before the manifolds arrived. I made up a set of billet adaptor plates to fit them to the EMI manifolds and was debating getting them cut down to the same height as the EMI SS Risers but I'm not sure if it's worth the effort?
It's hard to pick when doing a custom install because I don't want to relocate the exhaust holes and I'm not exactly sure where the exits on the EMI risers (SS or cast) will need to be.
Trial and error is fun, but it costs money.
Anyone need two pairs of 496 Risers? Going cheep!
(I have two pairs, don't ask why...) :rolleyes:
Rockfish71 04-29-2009 06:19 AM
Originally Posted by Ghostrider (Post 2855021)
Thanks Rock.
The emi's will be as close as a stock riser would be..... the 496 riser you have is all different I have both emi stainless risers long and short talls I will be selling the short risers soon they are brand new just idle time if your interested let me know we can come up with a great deal I will ship them to you not a problem. here is the risers I have http://www.eddiemarine.com/store/car...&p=13039&c=249
Ghostrider 04-29-2009 08:10 AM
They look great! And they are about the same height as the cast style? (approx.)
I'll fit these cast ones and make sure they work and then probably upgrade to your shorties if they'll fit.
Thanks!
John
(seriously, anyone want my 496 risers? I can't use them!)
