-   -   GPS Speedo Instal (https://www.offshoreonly.com/forums/general-q/207929-gps-speedo-instal.html)
Ran-Dom 32 04-30-2009 01:05 PM
GPS Speedo Instal
I'm installing an autometer GPS speedo, what is recommended for 12v power source, I was going to use an a hot wire /ignition , or should a have it to a constant hot wire, does the recall clear once you turn the key off? or what is the correct source for power
Ran-Dom 32 05-01-2009 08:17 PM
ttt
Elite Marine 05-01-2009 08:19 PM
Should have a wiring diagram. There might be a constant hot. If you do wire it to a switched power source, you will lose your top speed.
If you need literature, email me the part number and I will get you a diagram.
[email protected]
Kirk
Ran-Dom 32 05-04-2009 08:24 PM
I have a wire diagram, it's not real specific, red wire - 12v source, I wired it to the key switch, if it were live 24/7 I think it will run down the battery?
