Greasing Coupler: Question
I have all the manuals for the 496, and I read in one that if you do a lot of idling, or closed throttle through minimum wake, you should be sure to re-grease every 50 hours... I took it as meaning more often.
I would think that WOT would require more... more revolutions because of higher RPM. It just seems backwards. Any thoughts? |
8 cyl pulses at idle hammers on the coupler splines
| All times are GMT -5. The time now is 11:54 AM. |
