Lunati 54867lun cam ?
I have a genvi 502 with afr 325cc heads I was looking at that cam the specs are 230in 240ex at .050 .554in .575 ex at 114 lobe sep. I can get this cam from a friend for $100.00 it is out of his 502 bike . Any thoughts?
Originally Posted by Beeman
(Post 2858766)
I have the heads coming from afr. so the engine is already have it apart old heads bent the intake valves. I just wondering if cam would be ok for a boat. I seen your posts it was alot work to get it to work . I see that rmbuilder is the man when it comes cams.
I fig if i'm already there and if this cam will work I put it in . mine is a gen6 roller mpi engine . |
(Post 2858766)
I have a genvi 502... I can get this cam from a friend for $100.00 it is out of his 502 bike . Any thoughts?
Not a bad cam, but in a BIKE??? Your friend is nuts. |
I have a nice comp cam/isky springs and morel lifters that would work awesome with those heads-$500 for the package,cam is 604/612 lift,236/244 duration,let me know if you are intrested.
yes he is also has 150hp shot of nitrous. he switched to a soild roller to rev it to 7500rpm .
Originally Posted by ak
(Post 2859099)
| All times are GMT -5. The time now is 11:54 PM. |
