Mercury Vessel View ??
can anyone tell me the different part numbers for Vessel View and Vessel view race edition?
Originally Posted by BRUCE SEROFF
(Post 2861924)
79-898277K02 Standard Vessel View This one goes for bout $1200. I'm sure the race version is probably more. I think the Race version of this product is the coolest thing in boating right now. Just my opinion. If setup properly and if it works like they say, it actually works as a slip indicator much like the one from Livorsi but way better. It's tied to drives and tab settings and overall helps maximize the hull/power. Wish I could afford a boat that already has it installed and dialed!! Of course, it does way more than just this. It's way nice in theory. |
Sc 500
Now can anyone tell me how to reset "fuel used" in this SmartCraft Monitor?
Been on the phone with Merc 3 times now. They trip, they fall, and then don't call me back. I have a feeling that it's not re-setable. Is that a word? Probably just a data field that is non edited. |
Vessel Vew Race Edition
Here's what it does. Screens and layout are totally customizable.
Vessel Information: Boat Speed (from Pitot, Paddle Wheel, or GPS) Water Depth Fuel Tank Levels Air Temperature Sea Temperature Port, Starboard, and Center Trim Tab Position Outboard/Drive Trim Position Inches Traveled Per Engine Revolution Remote Oil Tank Levels Boat Fresh Water Tank Levels Boat Waste Water Tank Levels Total Vessel Fuel Flow Range Fuel Used Average Fuel Mileage (0.01 resolution) Instant Fuel Mileage (0.01 resolution) Clock/Time Peak Speed GPS — Bearing to Waypoint — Speed Over Ground — Course Over Ground — Distance to Waypoint — Time to Waypoint (calculated from GPS data) — Fuel to Waypoint (calculated from GPS data) — Dedicated hi-speed GPS antenna Engine Data: Engine RPM Engine Water Press ure Engine Coolant Temperature Engine Oil Press ure Engine Oil Temperature Engine Fuel Flow Battery Voltage Engine Boost Pressure Engine Fuel Pressure Fuel Pressure Delta (regulated fuel pressure) |
Originally Posted by SDFever
(Post 2862170)
Is there a add on sender the unit need to see in order to read the tanks. Ive trird to get info from Merc with no luck
(Post 2862170)
Originally Posted by jrz
(Post 2921462)
My Smartcraft resets the fuel used by holding two port side buttons down for about 2 seconds. Usefull gauges when compared to the inaccurate stock fuel level gauges.
it is nice though. mine will not reset regardless of what i do.... |
| All times are GMT -5. The time now is 03:34 PM. |
