In gear stall
Just rebuild the carbs on the motors. One is dead nuts the other stalls in gear sometimes. Once i get it going its cool just rather have it 100 percent. I will be putting it back in the water to set it and final tune.
Thanks Mike |
What carbs?
4150 850's
It sounds like you need to turn the idle mixture screws out 1/4 turn more.
Originally Posted by waconda
(Post 2864862)
PERFECT NOW !!:evilb: The 4 little air bleeds on the side of the float bowl,,turn them all the way in and then each 1 turn 3-3.1/4 turn's out,,,that should be it . Also adjust the float . U want it to be set the way the boat sits in the water ,,so tilt the trailer up a little in the front, then open the big plug on the side of each float bowl,,then adjust until the fuel is at the edge of the bottom of that hole,,if u shake the boat a little it should barely spill out fuel !!!!!! |
Thanks Guys will do today or tomorrow.
Mike |
| All times are GMT -5. The time now is 10:09 AM. |
