Boost referanced carbs
Can I use boost referenced carbs on a na motor? If so what would I do with the reference port ,Hook it up to manifold vacuum?
should work fine, still signals the power valve...Rob
ttt
Check the jett sizes if they sat on top of blowers, they will probably be larger in the primaries and secondaries than you will want in NA motors....
| All times are GMT -5. The time now is 08:57 PM. |
