-   -   shift interupt switch.... (https://www.offshoreonly.com/forums/general-q/208965-shift-interupt-switch.html)
picca00 05-16-2009 07:16 PM
ok i got a tough question here. i just finished getting the 502 mag into the 18' glastron after working on a custom fuel system. engine starts and runs fine, but i have to hook up the shift interupt switch some how and dont know where to run the wires to. its a 96 502 mag mpi and im using an alpha drive so i need to have the interupt switch. (bravos dont use this switch). my question is where do i run the wires from the switch to.? in the carburator version they go to the distributor or coil, but i have a mpi motor so i know its different. i wanted to look at a wiring diagram from a 350 mag mpi with alpha set up, but didnt know how related to computer functions would be or how different the switch set up would be? so if any body can tell me where to run the wires from the shift interupt switch id really be grateful. thanks jay
Sledge Hammer 05-17-2009 08:37 AM
Not sure about the switch. Not to burst your bubble, but I am wondering if it is worth the effort. I can't imagine you are going to make an Alpha live behind a 502 for any time at all.
crapr6 05-17-2009 09:29 AM
Sorry I cant help you with wiring it up, I know what the shift interupt switch is for but what will happen if it isnt hooked up? Reason I ask is my buddys 3.0L 4cyl motor w/ alpha 1 drive dosnt have the shift interupt switch hooked up and everything shifts smooth and he has no problems. Sorry for hacking your thread its just iam wondering what the deal is with it.
Erik
Young Performance 05-17-2009 11:04 AM
You can tie it in to the purple wire in the 10 pin harness. You can look for the wire just after it comes out of the plug on the the rear of the engine. Just cut the purple wire and run it in and out of the interrupt switch. The purple wire is what powers up the ecm, fuel pump, ignition, etc on an efi engine. It is the same wire that goes to the kill switch up by the dash. You could also use the pink wire that runs between the coil and distributor. This will only kill the ignition. Either will work fine. Hope this helps, Eddie.
picca00 05-17-2009 11:19 AM
Erik
you cant shift out of gear back into neutral with out it for me... i have to shut off engine to disengage.
eddie what about the est line (white) that comes out of the ecm at pin J1-10 and connects to the distributor at pin d?
thanks for the help jay
crapr6 05-17-2009 02:24 PM
Gotcha, my buddys motor is carb so he has it set at 650rpms idle and thats probley why he can pull his out of gear so easy. I guess with you having fuel injection lowing the idle is not going to happen. Good luck wiring it up.
Erik
MacGyver 05-17-2009 05:29 PM
Originally Posted by picca00 (Post 2867381)
ok i got a tough question here. I just finished getting the 502 mag into the 18' glastron after working on a custom fuel system........
Probably a little off topic. But does your insurance provider know about your upgrade to a 502 MAG? Better let them know, otherwise you could be denied a future claim.
picca00 05-17-2009 07:09 PM
cant get insurance that is worth anything, my boat is a 1978, it got a total custom build thats super tech. alot of money and time was spent here. also i try to stay away from idiots that dont know how to drive. insurance would be nice if i could get it valued at 20k! but that wont happen.
Pismo10 05-18-2009 12:37 PM
I agree, wire it into the kill switch. Drive it easy, small prop, higher rpm range and the Alpha will last a while.
bowtie 05-18-2009 05:06 PM
picca do you have pics of that boat. I have the same boat that has been abandoned in my yard that is in nice condition. I've thought about restoring it, such a classic look. Never thought about putting a 502 in it though.
picca00 05-18-2009 09:47 PM
ok so it was either the white wire or the pink wire that runs into distributor, we started with the white, while the engine was running i cut the wire and the engine died, just what i was hoping, we wired up the new switch gave it a test fit and tried it. it seems to be working fine except it stalls if you hold it too long. i know i just have to adjust the cables and switch position, but i was abled to get it in and out of gear foward thru reverse.
i would like to thank eddie from young performance for helping point me in the right direction, i think the pink would work too, but i dont know what the difference would be and how it effects everything if any.
heres a few pics from today, the boat is far from complete but it went through a major transformation, new everything with new tech, i cant wait to get motor broken in and run it good, was at 40 mph at 2000-2200 rpm with small 23" prop to break engine in with. hers the link to the whole build...
http://www.classicglastron.com/phpbb...php?f=20&t=169
http://www.classicglastron.com/phpbb...1262&mode=view
Pismo10 05-19-2009 07:30 AM
As annoying as that shift switch can be, you really do need it.
ACrooks69 05-19-2009 10:51 AM
Not to get to far into semantics, but the correct way to hook up the shift interupt with a Thunderbolt ignition it to tie the grey wire from the interupt switch to to white/green wire coming out of the distributor. This will ground out the magnetic pickup (or hall effect) in the distributor and command the module to stop firing momentarily allowing the gears to disengage. Going through this right now on my 5.7EFI bravo 3 motor into a alpha 1 boat. Hooking into the Purple wire will kill the ECU momentarily, but it is doing so by causing a dead short to ground. Probably not the best way if you ask me. Looks like you are on the right track though.
picca00 05-19-2009 12:39 PM
its an efi motor so i dont have thunderbolt ignition, the white wire works fine. breaking in motor this week, weekend is the air show so ill be ready to go fast!
