Blowers getting hot - how hot is too hot?
I have Blower Shop 250's on top of 502's.... I just changed the pulley's from 4.10" down to 3.85" to bring my boost up from 3.5 lbs to 5lbs..... I noticed after some test runs on Saturday, the blowers are getting really hot to the touch. Much more hot on the front and top than on the back. They just came back from The Blower Shop from being freshened.... Is it normal for the blowers to get really hot? Any input here would be much appreciated, thanks.
Compressing air makes it hot. 5 lbs of boost can be over 150 degrees. That's why people use intercoolers. Maybe you need more ventilation in your engine compartment.
They all get hot when running. You probably just never checked them before.
Thanks guys, honestly, I dont think I have ever really checked and might eb just worrying too much.... overall, 5 lbs of boost, TBS 250's... not much really to be concerned with as far as heat, right?
I dont have room for intercoolers, and have all the ventilation I can really get in there..... |
Originally Posted by eichhoma
(Post 2868264)
I dont have room for intercoolers, and have all the ventilation I can really get in there..... are the TBS 250's about the same as B&M 250's? Mine run about 5 lbs i think so i will check mine over the summer. |
Originally Posted by BDiggity
(Post 2868302)
Break out the jigsaw, time to add some scoops to that hatch. :party-smiley-004:
are the TBS 250's about the same as B&M 250's? Mine run about 5 lbs i think so i will check mine over the summer. I think they are pretty much the same.... 250 c.i. pretty close in physical size as well. I called Eric at the Blower shop and he said that was perfectly normal. |
My 177 on my 525sc would get very hot. You could barely touch it.
I would change the lube every 25-30hrs. |
| All times are GMT -5. The time now is 06:36 AM. |
