-   -   2000 32 fever (https://www.offshoreonly.com/forums/general-q/209100-2000-32-fever.html)
266ltd 05-18-2009 05:57 PM
2000 32 fever starting issues
i have a 502 mag mpi low hours aprox 190, that is not wanting to engage the starter i turn the key to the on pos. and the start alarms beep then when they are done i try to crank and just hear a faint click, i just repl. the bateries with exides. When i kick the key off and back to on, then crank, it will crank and start a bit slugish sounding crank but when it fires it runs fine? is it the starter going bad? bad battery? i did check conections, going to bring boat home and go throught it all, just a few ideas on were to start. hope its not the starter i have to pull motor to get to starter i think.
266ltd 05-18-2009 06:15 PM
i am going to go a head and loo into relp. the starter selenoid switch, anybody have a part number?
266ltd 05-20-2009 08:24 PM
well now ive done it!!!.. i got a new slave selinoid and before i repl. to trouble shoot i jumped across the two big wires, well sparks and a very responsive starter and it sounded good. so i removed the slave selinoid and put on the new one, as i was tightening it the large wire's nuts my wrench touched the 5/16 bolt and sparked well stupid me left the power on and now i have nothing. i checked fuses all ok, both breakers on the motor ok and all my other breakers ok. when i jump between the two wires on the selinoid nothing, and i even tryed jumping around the breakers on the motor nothing, i dont get any thing when i turn the key just dead. help please im out of ideas.
