-   -   Exhaust Manifold Driping? (https://www.offshoreonly.com/forums/general-q/209122-exhaust-manifold-driping.html)
HammerJake 05-18-2009 08:55 PM
So, I was running the boat on the garden hose today and noticed that both manifolds are dripping water slowly, one spot on each side. The boat is a 1999 Baja Hammer with a 454 non mag with 160 hours. How bad is this? I'm guessing it was happening last year but I never noticed it? Should I replace them asap? or can it wait? Money is a little tight, what do ya guys think? Thanks, Jake
SDFever 05-18-2009 09:02 PM
If they're leaking where you can see them what about if they're leaking where you can't???? A tight budget now will be worse later if you fill the engine with water.
Better to take them off and insure a dry engine and then fix it later when you have extra green.
You should be able to just get them off at least to satisfy your concern. Just my opinion.
Boat Tech 05-19-2009 02:15 AM
x 2 the parts are not that much right now BUT it will be soon. And you might have enough help "here" to do the work your self to save on some labor time. Just my opinion also.:party-smiley-004:
c_deezy 05-19-2009 02:36 AM
First of all, where exactly are they leaking? Where the riser comes off the manifold I'm guessing? Pics would help.
That is the common place they start leaking. You need to pull the risers off and replace the gaskets.
HammerJake 05-19-2009 09:06 AM
they are leaking next to the bolt heads that fasten the manifold to the head.
SDFever 05-19-2009 10:16 AM
See again, to make sure it doesn't go from bad to worse pull the whole thing off and make sure it's not getting in the cylinder(s).
Although it's common for the riser gaskets etc to fail first, this does not always apply especially if for instance a lot of guys buy risers at a different time then when the manifolds were bought. If you bought a used boat or engine it goes on and on.. Pull off both sides and have a look. It's cheap to do it yourself.
Throttle Fever 05-19-2009 02:45 PM
Could they of froze over the winter??
Dock Holiday 05-19-2009 03:15 PM
That was what I was thinking. Seems strange they would both start leaking at the same time.
I would pull them both off and do a complete inspection looking for cracks. If all looks good install them back on with NEW gaskets and bolts and you can count your self lucky.
jeffswav 05-19-2009 03:37 PM
I agree with these guys. Do not gamble with water leaking. Riser joints are a common failure, however you should see water leaking at the joint. It they are cracked they may leak between the manifold and head. I would pull them off and inspect them. If they need replaced get a good aftermarket manifold. I use the EMI Thunders, many others are available.
tcuda499 05-19-2009 05:26 PM
I got a nice set of new manifolds for $320 for a BBC off Ebay. Good quality and a good price.look around.
