oil pressure gages
i have a new livorci oil pressure gage . the needle wont move if i pull the sender wire and run a wire to the sending unit it pegs? put a new sending unit in and it does the same what am i doing wrong?
Originally Posted by johnnyboatman
(Post 2870253)
1 wire to the gauge ,,thats it !! The sender gets ground from the thread !!:party-smiley-004: |
i aint grounding anything wire to sender, gages grounded to dash.
(Post 2870268)
What kind of sender is it ? 1 or 2 terminals ? 1 say's G and 1 say's W ???? Then the G is GAUGE , i am not trying to be smart ,,but most think it means ground !:eek: ALSO ,,,,,COULD THE WIRE BE DAMAGED SOMEWHERE ?? |
the gage has a S which means sendor,g means ground
(Post 2870488)
(Post 2870268)
The only Ground on the gauge would be for lighting ....the Gauge is Gnd Through the sending units ......m |
whats it mean when the gage pegs, i tried a diff gage and it did the same thing, i bought new gages and am using a oriellys sender should i buy one from livorci .
(Post 2870992)
Its A Twin Engine, The Problem Side Is Wired Like The Good Side. Im Banging My Head Against The Wall
| All times are GMT -5. The time now is 10:35 AM. |
