Dyno Time Any Guess HP
The motor goes on the Dyno Monday . It a 516 cdi Dart Heads 9.0 to 1 compression and a RM builder cam . Any guesses on the numbers on a 2006 dyno . This will be all motor no accessories.
Joby |
545 -----575hp
585 hp with a reasonable correction factor i.e. real atmospheric data input not hurricane eye barometric pressure.
With AFR heads and 9.6:1 I would predict 620 hp.
570hp at 5400rpms.
Originally Posted by Thunderstruck
(Post 2871238)
Originally Posted by Griff
(Post 2871287)
570hp at 5400rpms.
Originally Posted by formula 382 sr-1
(Post 2871317)
The dyno will not let us change the weather station, It is what it is !!!!!!!!
(Post 2871318)
We just dynoed two 516 EFI'S (hp500 EFI ) with 741 cams Merlin 320 heads 9.3 compression . One made 570hp the other made 582hp both at 5500rpm.
Originally Posted by ROTAX454
(Post 2872002)
What dyno equipment is the motor tested on? Tested to what standard?
| All times are GMT -5. The time now is 07:08 PM. |
