-   -   prop& drive (https://www.offshoreonly.com/forums/general-q/20980-prop-drive.html)
Excalibur 03-28-2002 06:26 PM
Thanks for your help guys,looked into upgrading trans. but would have to move engine forward 7 inches and would be in back seat,thats why i was looking at bravo or b-max,even if i upgrade
boat,engine will go with me,took 15 months to get that raised
cam pro block,not letting it go and can punch it out 4 more times.
Besides i like the boat,you know sentiment-first boat.
Excalibur 04-05-2002 05:51 PM
So has anyone done a trs to bravo swap?
David 04-05-2002 06:29 PM
Excalibur- doing a bravo swap should be easy and would give you some extra room. I have the 72C in mine and it is VERY tight to the back seat. I did discuss this with a manufacturer who used to install the same setup in another brand boat and I was told they removed a section of the seat to put the engine in then replaced the section. I'm in the process of doing another Excalibur 24' but am sticking with the TRS/BW setup.
