500hp with msd boxes ??
my 500hp i just refreshed and powered up are carb motors with msd boxes spinning 30 bravo 1 and it sounds like im in a revlimiter at wot at 5550 to 5600 if i back out a bit to 5300 or so all sound great. with the msd boxes do they overide the rev limiter or not ,,still stock ignition system and im thinking i need a bigger prop now.
The Msd box will not over-ride the stock rev limiter, the marine box has it's seperate rev limiter that you add to it.
You rev limit had already been modified. The stock rev limit on HP500's is 5350rpms. I'm not sure what was changed originally to increase the rev limit.
I actually just got a response from joe that it still uses stock rev limiter, and im in it for sure so time to prop up.
in most cases, just being in possession of an MSD is like having a limit on your revs... often set at zero
Originally Posted by stevesxm
(Post 2877380)
He means the MSD boxes tend to go bad a lot.
Rick,
what was your speed and avg rpm between the 2 motors? |
Originally Posted by Thunderstruck
(Post 2877788)
Rick,
yeap...MSD=may soon die
Originally Posted by ezstriper
(Post 2880295)
| All times are GMT -5. The time now is 01:04 AM. |
