-   -   525 efi Header Gaskets? (https://www.offshoreonly.com/forums/general-q/210313-525-efi-header-gaskets.html)
outriggers 06-04-2009 05:56 PM
We didn't have gaskets, so we put the headers on with a front and back bolt. The gaskets are slotted so I don't have to remove the header, just slide the gasket in. Can the gasket go on both ways? I don't want to remove a header to find out if I don't have to. Thanks, Doug
Elite Marine 06-04-2009 07:08 PM
I think it will only go in one way...not 100% sure, but I remember having to take mine out and turning it around. You dont need to remove the header to figure it out, that I know 100%
Panther 06-04-2009 07:15 PM
the way you're doing it is the best way to do it. You can't put it on backwards, the holes wont line up and it will only fit one way.
when I buy gaskets that aren't slotted, I cut the ends and slot them myself. :)
