-   -   Deadrise?.......... (https://www.offshoreonly.com/forums/general-q/210778-deadrise.html)
moxxy13 06-11-2009 04:49 PM
Deadrise?..........
Hello all. I purchased my first offshore last year. I was wondering how deadrise is measured. What would be the technical term for the amount of the v-hull that rises out of the water in height. some boats seem to have a lower side profile and others seem to raise high out of the water in the front/bow. Thank you for your input.
onesickpantera 06-11-2009 05:03 PM
Deadrise is the angle of the V at the transom and is measured from horizontal.
I'm not really sure what you mean about the other question???
endeavour32 06-11-2009 05:12 PM
The answer to your second question is freeboard!
onesickpantera 06-11-2009 05:18 PM
I kinda thought that too but the "raise high out of the water in the front/bow" threw me.
moxxy13 06-11-2009 10:10 PM
I know what freeboard is.............I will try and find an example and post back...thanks
Philm 06-12-2009 02:18 PM
While I still think you are thinking of lower stern freeboard and higher bow freeboard, perhaps you are thinking of "sheer"
Sheer is the upward curve or amount of upward curve of the longitudinal lines of a ship's hull as viewed from the side. While this is not usually common in performance boats, as most seem to have a fairly level deck height, this seems to fit what you are trying to say the most.
moxxy13 06-12-2009 10:04 PM
Thanks Philm......
Philm 06-13-2009 12:18 AM
No problem man, hope this helps
