-   -   milky oil around oil fill caps (https://www.offshoreonly.com/forums/general-q/210976-milky-oil-around-oil-fill-caps.html)
rssteiny 06-15-2009 06:59 AM
I noticed i have a thick milky oil around my oils fill caps when i screw them off, not on dip stick and oil pressure is great, is it due maybe to the fact i dont run hard much where we boat and my oil tems never get above 190 ,, just a bit worried due to the new 741 cams with reversion but it seems to only be in the valve cover area up high near the fill caps and i do see some coming up the breather tubes to the arrester.
jeffswav 06-15-2009 07:23 AM
What exhaust are you using?
rssteiny 06-15-2009 08:25 AM
gill with the tall long risers and i welded a 1/2" high peice of stainless across the pipe behind the water dump holes.
Elite Marine 06-15-2009 08:50 AM
Do you run oil stats? You need to get the oil up over 212 to get the water out of the oil. This is a typical and common problem. To verify reversion issue pull your plugs. They are probabaly fine.
Get an oil thermostat and your problem will be solved!
rssteiny 06-15-2009 08:55 AM
Where would they be located in the cooler somwhere
rssteiny 06-15-2009 05:34 PM
how hot should they be running at like 3500 for a few miles
BenPerfected 06-15-2009 07:19 PM
The first step is to get an oil temp gauge. Gauge and sender is less than $100. Elite Marine can sell you both.
Elite Marine 06-15-2009 08:37 PM
Good point Ben. Email me at [email protected] and we can discuss this further. I will help you out with cost too. Hate to see you ruin an engine due to condensate.
Do a search on here for oil thermostats to determine which one you prefer. Some are cheap and I dont know how well they last, others are very expensive and not worth the money.
I dont pick products for people, just show them their options.
rssteiny 06-16-2009 06:55 AM
I have oil temp guages, as i said they dont get above 190 much do to short runs where i boat, now this weekend im doing a poker run ill see how hot they get when running for long periods of time.
