-   -   3 psi fuel pressure switch (https://www.offshoreonly.com/forums/general-q/211184-3-psi-fuel-pressure-switch.html)
502ss 06-17-2009 02:46 PM
I just installed blinking LEDs and buzzers in my dash and I am looking for around a 3 psi switch I can hook up to my fuel pumps so if the pressure drops to 3 psi or lower that it completes the circuit and trips the led and buzzer. Any ideas where I can get something like this? I have done some looking but not having much luck finding anything.
Jeff P31 06-17-2009 03:21 PM
Summit or Jegs
502ss 06-17-2009 05:12 PM
:lolhit: Looked at all the different marine super stores but never thought about looking at Jegs or summit. Thanks!
Now before I pull the trigger I need a second opinion.....
I think this is what I am looking for
http://www.summitracing.com/parts/NOS-15750NOS/
What I want to double check on is that it sounds like at 5psi and higher the switch is open and at 4 psi and lower the switch is closed. Does that sound right?
axapowell 06-17-2009 08:25 PM
I have 2 in the box ready to ship that are adjustable. Interested?
Dave
Rookie 06-17-2009 09:50 PM
http://www.gaffrigperformance.com/Pr...SubCategory=66
502ss 06-18-2009 07:55 AM
Thanks everybody, I know have several locations to buy them from. I am still wondering about wheter I need a normally open or normally closed? Based on my post above it sounds like I want one that is normally closed which means below 4PSI the switch is closed and above 4 it is open? Sound right?
502ss 06-18-2009 08:14 AM
ok, so I just read the documentation and maybe I need a normally open instead. It sounds like the nomally closed are a closed circuit when above 4 PSI and when below 4PSI it opens the circuit. :lolhit:
Rookie 06-18-2009 08:35 AM
Yes normally open means when things are going good the circuit will be open (no continuity) when switch fails to achieve proper pressure the switch closes and creates the continuity loop and lights your dash light and or buzzer.
502ss 06-18-2009 03:03 PM
Great, thanks man!:drink:
502ss 06-18-2009 03:07 PM
Dave
What's the psi range? Are they normally open? How much?
Jim
