-   -   milky foamy trans fluid (https://www.offshoreonly.com/forums/general-q/211274-milky-foamy-trans-fluid.html)
tgersx 06-18-2009 03:18 PM
what would cause a foamy milky like trans fluid in a huber 1350 trans? what i recently changed the fluid and put dextron in it. Now it's foams up and comes out the vent tube and when i pull the dipstick its full of red foam.
07DominatorSS 06-18-2009 04:16 PM
Does it call for Dexron or Type F fluid, that might make a difference?
picklenjim 06-18-2009 04:17 PM
Does that trans have some type of cooler?If so you may be getting water into it through the cooler.
Lmarth 06-18-2009 06:35 PM
My Huber 1330's specifically called for Type F. For what it's worth...
