-   -   HELP! Need size for hydraulic steering fittings (https://www.offshoreonly.com/forums/general-q/211316-help-need-size-hydraulic-steering-fittings.html)
TexomaPowerboater 06-19-2009 09:05 AM
3 Attachment(s)
I know I should of just grabed the lines and take them up to the store, but the boat is out of town and I need help figuring out what size fittings I need. Here is a picture, basically were having to run some 45* fitting adapters to get our bellhousing mounted oil coolers to fit. So we need to replace the 4 straight fittings for some 45*'s, but I don't know the size. Any help would be greatly appreciated. They are for the center hoses (orange).
niceguy 06-19-2009 09:49 AM
They look like #6 size which is about 3/8". But it is hard to tell by just the picture.
DareDevil 06-19-2009 09:49 AM
First of,,,u need 90's and T's,,,size ??????????? They are all diffrent.
Rookie 06-19-2009 10:00 AM
My system uses #6 with 1/2" hose 3/8" NPT where threaded. It looks like you have 3/8" hose with #6 fittings.
A little off topic, but where is the best place to get the thru hulls for hydraulics? I need 4 of them.
TexomaPowerboater 06-19-2009 10:06 AM
1 Attachment(s)
Here is where I'm at now. Why 90*'s?
Jb-fse 06-19-2009 11:43 AM
Fittings
The Hose You Have Apears To Be Size #6 (3/8). The Picture Of The Cross Over Hose That You Have Run Shows That Those Lines Will Fail Do To To Tight Of A Bend Radius. We Also Have Thru Hull Stainless Bulkheads In Size #6.
Rookie 06-19-2009 12:13 PM
Whose we??
DareDevil 06-19-2009 12:20 PM
1 Attachment(s)
Because it looks cleaner and its press. so it will not restrict anything.
The 45's will still stick out,,why would u want to do that ??
+ u don't need to bend the hoses ,,which is not good for them.
Just me !:party-smiley-004:
DareDevil 06-20-2009 09:48 PM
1 Attachment(s)
Andy here is a picture of a Hustler.........u see the 90's very good.
WORKS FINE !!!
