-   -   thunderbolt 1V ignition question (https://www.offshoreonly.com/forums/general-q/212001-thunderbolt-1v-ignition-question.html)
alecsammy 06-29-2009 08:44 PM
I have a stock ignition , my timing jumped 10 degrees not sure what caused this to happen. I had changed the jets and noticed some popping out of the carb, I readjusted the the timing and now is fine . Can the module cause the timing to change , the distributor was tight so it was not the cause. any suggestions.
Griff 07-02-2009 01:38 AM
The base timing should not change unless the distributor moved. Somehow it moved or you have a dist gear that jumped.
