-   -   Marine vs auto ignition & plug wires (https://www.offshoreonly.com/forums/general-q/21210-marine-vs-auto-ignition-plug-wires.html)
kaamacat 03-31-2002 09:48 AM
NW_Jim.........In fact on the Taylor 135 degree, we just put a black set on my sons 1970 pontiac and are very well made also (to keep it that stock look). I guess (even though lots of folks may think the subject "simple), it depents on the clearences and how you want the stuff to look or hang.
Tinkerer 03-31-2002 10:07 AM
I have used the TAYLOR wires for about 10 years now and have had 0 problems with them. The other thing is the boots dont pull off the wires.
blown formula 04-01-2002 12:10 PM
US1 Fountain, maybe you should also consider the Jacobs marine multi-master ignition. Works great & uses the stock igniton module for the curve. Works great, really a hot spark & I have never heard of any corrosion problems. If a failure occurred with the Jacobs, you move one wire to go back to stock ignition system. It's always nice to have a "backup system" when you are far off shore. This is it. It comes complete with cut to fit wires (no radio interferance- am/fm/uhf/vhf). It looks good also. It worked for me. Just another .02! :rolleyes:
kaamacat 04-03-2002 07:19 AM
US1 Fountain.
I did get a reply from the MSD tech. He (they) said that the only way you could have a problem was if there was a bad wire. (the short version).
US1 Fountain 04-03-2002 06:37 PM
kaamacat, thanks for the update!
I ordered the MSD wires last night from Summit.
BTW, the pt # 3123 you suggested have the 90* boot for HEI. (Has the little tit on boot top for the wire holder) I ordered the 3122 that have the plain 90* dist. boot that is like whats on the Merc distribs. Got this number from the MSD site, as Summit has their pictures and descriptions switched around. Both are the same wire and 90* plug end, just different style of distr boot.
Thanks for the help,
Jerry
kaamacat 04-03-2002 09:49 PM
US1 Fountain.....cool........Yea, the 3123 comes with both just in case you have the HEI setup. Just take some time to measure then cut.
Bob
boomer 04-04-2002 08:29 AM
Replacement auto wires with the correct angle boot where hard to fine I end up using Mercruiser, on my 88 7.4 bravo
Lee 04-05-2002 07:28 AM
Originally posted by kaamacat
US1 Fountain.
I doubt that I had a Bad wire since those MSD wires that I removed are still in service and running good on a non Knock T-bolt ignition system.:confused:
candyman35 05-21-2002 12:11 AM
TTT
CheckmateF1 05-21-2002 12:24 AM
CandyMan, Did you do that for me? Thanks! You got my mind going hammer down now.
Guess I should get a set of Merc blue's and try them out, Huh?
Eric
