Oil Filter Removal >
Oil Filter Removal
Oil Filter Removal
Old 03-30-2002 | 09:09 AM
hp500efi's Avatar
Member #9
Default Oil Filter Removal
Last few times I changed the oil on my motor, the oil filter was a real ***** to remove. I mean it was on there so tight I almost ruined my filter wrench trying to remove it.
Any suggestions? is it that I am putting the filter on too tight? I don't like the bugger to leak . I always pre-oil the new filters gasket before installing.
Thanks Jeff
Member of the Liquid Jungle
hp500efi is offline
Old 03-30-2002 | 10:06 AM
kaamacat's Avatar
Hp500Efi......So far, I've always had good results just putting oil on the gasket(like you did), then giving it a "quick spin" for it to touch the mount base. Then just that 3/4 turn by hand.
kaamacat is offline
Old 03-30-2002 | 05:17 PM
MitchStellin's Avatar
use hand preasure only. They will tighten as they expand and contract. I used to do the same thing you do and crushed the filter to get it off.
MitchStellin is offline
Old 03-31-2002 | 08:56 PM
Spine Tickler
Are you putting a hole in the top of the filter to get rid of some of the vacuum? This might help. Spine Tickler
BeakBoater35
Fountain
34
01-30-2010 08:10 PM
Velocity Vector
0
04-03-2008 01:45 PM
powerguy
Fountain
2
08-04-2002 05:17 PM
